1 - 4 of 4 Posts
Has anyone had trouble with the fog lights going off and on on their own.
All connections appear to be intact.
Some times when driving and hit a bump in the road, the fog lights will come or go off on their own.
Any known issues with the switch?
Ex SoCal Nut
Not yet.... let us know what you find out.
04 SSR
Do both fog lights seem to turn on and off at same time?
There is supposed to be a light in the switch indicating they are on, I can't see it! If you can see it can you safely watch the light on the switch to see if it does anything indicating a problem?
If both fog lights are acting up you might check for a loose terminal at the relay or fuse (previous use of a fuse tap can cause a loose fuse connection), also for grins replace relay with another one with same part #.
1 - 4 of 4 Posts
