I have my Halo's on a separate toggle switch. I can leave them on during a car show. I try to run with my DRL's off and just turn on the halo's.What are the Halo's? does the Halo stay on like the DRLs or can they be used that way?
True, in many states it's illegal to run the fogs and high beams together.All factory installed fog lights I've seen only come on when low beam head lights are on.
Ebay. "Universal 3" angel eye Halo". Takes lots modification to install on stock fasica(bumper). They come with no instructions. $34.00 free shipmentSo, where do you get them????????
Thanks!
Dinerman - I like your Halo's. Very good looking mod. Did you get your Halo Lights off Ebay, as mentioned on this thread? Any installation problems to look out for? Your wiring diagram for toggle switch on/off? I'm looking into legality in PA.I'm lazy tonight, don't feel like doing a search on how to remove fog lights from bumper. Got ring off need a easy way to remove housing? Thanks
They seem to be available. I found this with a quick ebay search:Where did you get them?
Does anyone know if there is an LED bulb for the current fog lights.
Thanks
I'd like to know too, where did you get those combo (halo/fog) lights. I noted an ebay link in follow on post, but could not tell if that item was the same or not.Dinerman - I like your Halo's. Very good looking mod. Did you get your Halo Lights off Ebay, as mentioned on this thread? Any installation problems to look out for? Your wiring diagram for toggle switch on/off? I'm looking into legality in PA.
Thanks,
Paul
:| Seems like there are a lot of choices, some are over $100. but these look like they would work........Amazon... 3 inch halo. Angel eyes
I put rocker switch next to light control knob.. with led on indicator. Power came from always on power plug drivers side.. fused 1 amp. inline... ran though fire wall... just grounded neg. Just thought it was the best way for me.
Need to trim fog lamp bezel... make it round. Remove all old bracket. . Two side tape in new light... snap on bezel.. it holds tight.
Looks like the blue would match your ride. Might just be worth the chance...........................................................................................................................................................................................................................you might get a ticket.:wink2:The Blue ring may get you a Ticket from the authorities!!!!!!!!
They are same ones I have ... but in white. Work fine... just have to put round light in an oval hole.Looks like the blue would match your ride. Might just be worth the chance...........................................................................................................................................................................................................................you might get a ticket.:wink2:
P.S. Were you or anyone else able to see the particular ones I'm trying to show in my post via Amazon. I've not ordered them or any other of the multiple choices till I get some feedback as to which way to go.:smile2:
