1 - 3 of 3 Posts
Description Gap Parallel Flush
Folding Top Front Panel to Windshield Header 7.0/9.0 mm -0.05/0.05 mm -1/1 mm
Folding Top Front Panel to Rear Panel 7.0/9.0 mm -0.05/0.05 mm -1/1 mm
Folding Top Rear Panel to Rear Window Offset 9.8 mm -- --
Folding Top Rear Stowage Compartment Lid to Rear Window 7.0/13.0 mm -0.05/0.05 mm --
Folding Top Rear Stowage Compartment Lid to Roof at Door 6.7/8.7 mm -0.05/0.05 mm -1/1 mm
Folding Top Rear Stowage Compartment Lid to Door 4.0/6.0 mm -0.05/0.05 mm -1/1 mm
Folding Top Rear Stowage Compartment Lid to Extension Panel 7.0/9.0 mm -1.0/1.0 mm -2/2 mm
Folding Top Rear Stowage Compartment Lid to Quarter Panel 4.0/6.0 mm -0.05/0.05 mm -1/1 mm
Folding Top Rear Stowage Compartment Lid to Rear Compartment Lid 4.0/6.0 mm -0.05/0.05 mm -1/1 mm
Folding Top Rear Stowage Compartment Lid to Quarter Panel (Vertical Joint) 4.0/6.0 mm -0.05/0.05 mm -1/1 mm
How do I format this with columns? Vbullitin is eating the spaces.
BTW the parallel specs are +/- .002 inches. I know my car dosen't meet that.
use [code] and [/code]
There is a VB thingy that lets you put in preformatted info. Use [ code] and [ /code] , but you have to remove the space between the first bracket and the word code. It would come out like this (with a few redundant words left out) -
Code:
[FONT=Courier New][SIZE=2]Description							Gap		Parallel	Flush
Rear Stowage Compartment Lid to Quarter Panel (Vertical Joint)	4.0/6.0 mm	-0.05/0.05 mm	-1/1 mm[/SIZE][/FONT]
Diggs
P.S. While you are in there, would you look up the Bose system speaker sizes? There have been reports of everything from a 5" to a 6 1/2" to a 7 or 8" sub in the door.
Discussion Starter · #3 · (Edited)
Sure, soon as I get it working again. Something broke and I can't seem to get it either uninstalled or reinstalled.
PS: The manual is back on line now. But. it dosen't seem to list part numbers for anything shown in the service proceedures. Makes a kind of sense. You don't have to update the manual every time a partnumber changes.
1 - 3 of 3 Posts
