The time has finally come, I’ve been thinking about this for awhile now. It's time to move on to the next phase in my life. I've owned this beautiful 06 Pac Blue 6 speed SSR since December of 2013. I've driven it less than 1000 miles in the last 18 months. I Have added all the options available from MikeinAZ and several others. It currently has 40,769 miles on the clock. Here is a list of the accessories, as far as I can recall.
SALE ON HOLD!
Asking $31,000. I believe that to be a fair price considering all the options listed below.
General Information
Year:2006
Make: Chevrolet
Model: SSR
Color: Pacific Blue
Packages: 3SS
VIN: 1GCES14H06B121727
History
Build date, 8-31-05, 2nd owner, purchased December 2013 with 18,000 miles.
Modifications
Drivetrain
LS2 6.0L, built by Duttweiler Performance using all forged components and a modified cam specifically spec'd by Joe Delano for a 2300 blower (don't know the specs) installed, setup and tuned by Joe Delano, Left Coast 32, 11/2018.
Performance tune by Joe Delano, 11/2018
Corvette C7 Clutch assy. with remote bleeder. Replaced in 11/2018 when the engine was out.
Less than 500 miles since the engine/clutch swap
6 speed manual transmission.
Corvette C6 oil pan.
Wrapped the hydraulic clutch line with heat shield protector while the engine was out for heat protection.
Core/Hurst short throw shifter kit.
MikeinAZ oversized radiator.
MikeinAZ large capacity, oversized cooling fan, (This is the oversized fan designed for SSR's with modified engines). No it does not overheat, regardless of the air temp or how it's being driven.
MikeinAZ heater hose kit.
4.11 differential gears.
Eaton oversized differential pan.
Stainless Works long tube stainless steel headers, ceramic coated inside & out.
Heat blankets on each spark plug wire
Custom exhaust with X-pipe, high flow cats & Flowmaster Super 44 dual in-dual out muffler, (Sounds awesome!)
MikeinAZ’s exhaust tips.
Interior
Complete chrome kit. Added, not OEM
Chrome auxiliary gauge pod w/Speedhut brand gauges, monitoring volts, engine temp and an analog clock.
Core/Hurst short throw manual shifter kit.
One-off blue pearl Hurst shifter knob.
Fat-Matt sound deadener inside the doors.
Heat shield/sound deadener material on the under-side of the floor, up the firewall a bit, on the front of the gas tank, and anywhere else that it was practical to fasten it to (recommended by MikeinAZ, great advice, thanks Mike).
3M Tint on the side windows.
moleskin/felt installed to prevent window tint from scratching.
Plexiglass Wind suppressor, made by Wind SuppreSSR
Bling under the hood
Wilwood polished billet aluminum hydraulic clutch reservoir.
Dragon2u’s & Floyd Baileys Polished billet aluminum reservoir caps, chrome pulley covers, bolt head covers & misc billet aluminum plate covers.
Dragon2u,s Polished aluminum coolant tank w/sight glass.
Engine cover, smoothed and painted Pac-Blue.
Polished engine cover insert.
Chrome alternator with a March Billet aluminum Alternator Pulley.
Chromed hood hinges.
Polished Stainless Steel hood struts.
Fiberglass hood blanket with chrome SSR logo.
Fiberglass Hood emblem support, painted Pacific Blue
Custom built aluminum, polished cold air intake with Camaro card style MAF/IAT sensor.
K&N air filter & heat shield
Chassis/Suspension
MikeinAZ front frame stiffener kit
LC32 engine crossmember kit
MikeinAZ's Anti-lock brake control heat shield.
Addco oversized swaybars, front and rear
Bilstein Shocks, front and rear
Lowered coil springs, 1 “ front, 1.5” rear
MikeinAZ steel lower radiator support
Chromed trailer ball hitch with keys, never been used.
Exterior
MPD front spoiler.
MPD integrated side running boards.
Modified tailgate, "Chevrolet" insert from a 56 pickup. work done by Sinister Customs, in FL.
C6 Corvette license plate surround, painted Pacific blue.
Muth mirrors with turn signal indicators
3rd brake light flasher.
Full carpet kit in the bed.
Chromed Aluminum bed rails, instead of the wood/plastic rails.
Chromed deck lid cover hinges.
Polished Stainless Steel deck lid struts.
Polished cargo bar.
cargo net.
LED lights all around.
Two soft sided saddle bags
Koverking Indoor/outdoor storage cover, sorry, its red.
SSR branded fender gripper cover.
Audio
Kenwood DNX6980 in dash audio/video system with navigation, serius/XM, iphone integration, bluetooth etc.
Backup camera
Alpine MRF-X30 4 channel amp.
Focal IC-100 speaker system.
Wheels and Tires
Budnik Gasser 6 billet wheels, OEM size & offset.
Nitto NT555 G2 UHP tires. Purchased in April, 2019, less than 100 miles on them
Front: 245/45ZR19
Rear 315/35ZR20
MikeinAZ spare tire kit with a Trailblazer 17" aluminum wheel
Other stuff
I’ve got most of the OEM parts that have been removed when adding all the aftermarket parts. Anything I’ve got would be included in the sale.
And finally, the build sheet...
2006 Pacific Blue 6 speed
1GCES14H06B121727
Model: CS15703-2006 CHEVROLET SSR
Service Contract: No Branded Title: No Warranty Block: No PDI Status: No
Order Type: 70 - RETAIL - STOCK
Field Actions: 0 Open
Vehicle Build
Order Number: JGSPDD
Gross Vehicle Weight: 2,747
Build Date: 08/31/2005
Build Plant: B
Option Codes
6sp 3SS no VYJ 14P BVF ERH ERK E80 VR4 VXM
14P - CHROME PLATED WHEELS
192 – EBONY 19I - EBONY INTERIOR TRIM 1SZ - PREFERRED EQUIPMENT SAVINGS
3SS - 3SS PREFERRED EQUIPMENT GROUP CONSIST OF: * 6 CD CHANGER * BOSE PREMIUM SPEAKER SYSTEM * HEATED SEATS W/DRIVER MEMORY * AUTO DIMMING ISRV & DRIVER SIDE MIRROR * UNIVERSAL GARAGE HOME REMOTE * RUNNING BOARDS * AUXILIARY GAUGE PACKAGE
6DL - FRONT SPRING 7DL - FRONT SPRING 8KL – SUSPENSION 9KL - SUSPENSION
90U - PACIFIC BLUE METALLIC
A31 - POWER WINDOWS A95 - SEAT FRONT LEATHER SURFACES
AAB - MEMORY DRIVER CONVENIENCE PKG
AJ1 - TINTED GLASS
AJ7 - DR/PASS FRT & SIDE AIRBAGS
AU0 - KEYLESS REMOTE DOOR LOCK
B30 - CARPETING, COLOR-KEYED
BKF - CUSTOMIZED FLOOR MATS
BVF - RUNNING BOARDS - BODY COLOR
C49 - ELECTRIC REAR WINDOW DEFOGGER
CJ3 - CLIMATE CONTROL DJ2 - ISRVM LT SENSITIVE HOME CONV
DNR - DEALER INSTALLED EQUIPMENT
DR2 - MIRROR O/S LH & RH REMOTE CONT ELECTRIC, HEATED LT SENSITIVE, MANUAL FOLDING, COLOR
E55 - TAILGATE BODY
E80 - SOFT SIDE-SADDLE STORAGE DEALER INSTALLED
EB6 - GVW RATING 6,050 LBS
ERH - AUXILLARY GAUGES - BODY COLOR
ERK - CARGO COMPARTMENT TRIM W/ SIMULATED WOOD STRIPS
EVA - EVAP EMISSION REQUIREMENT
G80 - LOCKING DIFFERENTIAL-REAR AXLE
GT4 - REAR AXLE - 3.73 RATIO
JF8 - BRAKE VAC POWER, 4 WHL DISC
JJA - PT DRESS SUBASSEMBLY INSTALLED
K34 - ELECTRONIC SPEED CONTROL WITH RESUME FEATURE
KA1 - HEATED FRONT SEATS
KG3 - 145 AMP ALTERNATOR
LS2 - 6.0L V8 ENGINE
M10 - 6-SPEED MANUAL TRANSMISSION
N40 - POWER STEERINGN
NE1 - 50-STATE EMISSIONS
NU4 - CAL EMISSION SYSTEM, LEV2 PLUS
OLF - PLANT CODE - LANSING, MI PD7 - WHEEL, SPARE DELETE
PZ7 - WHEELS, 19X8 FRT, 20X10 RR
QMX - TIRE, ALL MIXED SIZES FRT & RR
R6P - PREMIUM PAINT
R8K - ***
R9N - LEATHER APPOINTED SEATING
SLM - STOCK ORDERS
STW - LEATHER WRAPPED STG WHL W/CONTR
T61 - DAYTIME RUNNING LIGHTS
T96 - FRONT FOG LAMPS
T98 - STAMPING VEHICLE IDENT NUMBER
U68 - DRIVER INFO CENTER DISPLAY U73 - FIXED MAST ANTENNA
UA6 - THEFT DETERRENT ALARM SYSTEM
UC6 - AM/FM STEREO W/IN-DASH 6 CD
UQA - BOSE PREMIUM SOUND SYSTEM
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
VK3 - LICENSE PLATE BRACKET-FRONT
VR4 - TOWING PACKAGE - INCLUDES SOFT SIDE SADDLE STORAGE AND FOAM HITCH INSERT DEALER INSTALLED
VXM - COLOR KEYED PACKAGE
VXS - COMPLETE VEHICLE LABEL
X88 - CHEVROLET CONVERSION YC5 - LT DECOR
YD3 - BASE EQUIP FOR SCH GVW PL-FT AX YD5 - BASE FRONT SPRING
YD6 - BASE REAR SPRING Z82 - HD TRAILERING EQUIPMENT
ZQ8 - SPORT HANDLING PACKAGE ZY1 - SOLID PAINT
Contact me anytime,
jjmeld@gmail.com
801-971-2414
SALE ON HOLD!
General Information
Year:2006
Make: Chevrolet
Model: SSR
Color: Pacific Blue
Packages: 3SS
History
Modifications
Drivetrain
Interior
Chassis/Suspension
Exterior
MPD front spoiler.
Polished cargo bar.
cargo net.
Audio
Backup camera
Wheels and Tires
Front: 245/45ZR19
Rear 315/35ZR20
Other stuff
1GCES14H06B121727
Vehicle Build
Build Plant: B
Option Codes
AJ1 - TINTED GLASS
E55 - TAILGATE BODY
R6P - PREMIUM PAINT
R8K - ***
SLM - STOCK ORDERS
Contact me anytime,
jjmeld@gmail.com
801-971-2414
