I saw the splined front hubs too. (mentioned in an earlier post, which I could not search out)
Using google I found only one on topic page. Here is the relevant quote:
The also saves weight with a new oil pan design. Due to the lower, shorter design of the SSR, the new "pan-axle" design allows the front differential to pass through the oil pan, resulting in weight savings, while optimizing the use of under-hood space. (Note: this paragraph was taken from a GM press release on the SSR, but GM may have used it by accident since there will reportedly be no all wheel drive SSR).
Has any body seen the reported press release?
