1 - 20 of 34 Posts
I was wondering if everyone is using Super 93 octane in there SSR or are you using lower octane without any pinging etc. Thanks
91 is as high as it gets here. $3.17/gal. Owners Manual says Premium.
SSR, An American Original book says 87 is fine. So let the debate begin again. It's been discussed before, try the search window.
I Use The Low Grade Wright Know. As It Is Winter And Ive Only Had It Since Oct. Ive Had No Pinging As Of Now. But May Move Up When It Gets Warmer Time Will Tell......
I'm using 93 now just because I'm not driving it very much, so what's a couple dollars more per fill-up? But I've burned both regular and midgrade in it on trips without issues.
Maximum power isn't one of my concerns, and I've yet to see compelling evidence that premium provides sufficient MPG increase (if any) to yield a positive return on the price differential.
OP
every gallon
93 every day...
I got the LS2, so I'm pretty much stuck with using 91+.
As far as the 5.3 and whether it would run better on 87 or 89 or 91+, I have to say that it could depend on many factors - weather, altitude, quality of the fuel, any engine or programming modifications, etc. I do know that for the past month+ I have been using 89 in my still stock Silverado and noticed that after the second tank that power had improved and mileage is up by about 1 mpg. Is that enough to warrant it? It's up to you to decide. I just got my westers computer yesterday, so we'll see just what the 89/93 dual tune can do. :)
Pinging
I'm using California 89 octane. Tried a tank of 87, but I thought I heard pinging under load. Haven't heard anything with 89:)
Timbrr said:
Ethonol 89 octane in my 2004. No problems, no lack of power.
Timbrr,
When I left Karl Chevy. One of the guys there told me not to put that stuff in my 06 SSR. I think he said it was made from Cow Feed. :eek
Octane Ratings & Ethanol
There is not much difference between Regular and Premium in my 2004 5.3L. Sometimes the fuel economy and power seem bit better with Premium, but that difference is at best minor and could be due to other factors than the Octane rating.
It would be interesting to know what the engine calibration is relative to detonation threshhold. If GM set the basic ignition calibration above that level and then uses the knock sensor to back out spark advance, there might be an improvement in power and economy.
As far as ethanol content in the fuel, it's only advantage is political (farm subsidies, tax credits, etc). Ethanol has about half the energy content of gasoline and and adding 10% to the mixture drops the fuel economy by 5%. If you fill up with an ethanol blend, make sure it is priced cheaper than 100% gasoline; it is worth less in driving range. (Worse yet, ethanol gives back less energy as fuel than went into growing & harvesting corn and processing it into ethanol according to a US DOE study published in 2001).
Had an 03, put 11600 miles with 87 octane, now have 04 put 7200 with 87 octane no problems with ping or low power/ looking for 05 just to get the 90 HP/ will never be without an SSR for the rest of my life/ May give up my 01 Prowler but never my SSR without already having another SSR in the drive.
Senior Privileged Member
The computer in the SSRs is smart enough to retard the timing if you use lower octane fuel, and it will run without incident, BUT it WILL produce less power.
The computer is programmed to try to use as much spark advance as safe, but once it detects any knock, it retards the timing aggressively.
So, you can use the lower octane ffuel, but you will have less power available.
93 and 100
93 normally. And 100 octane Sunoco lead free race fuel about twice a year to clean things out.
Fuel
Mason57 said:
Timbrr,
Mason57,
When I left Karl Chevrolet. They said it was okay to use Ethonol because all us Iowans are corn fed :glol
Timbrr said:
Mason57,
Sounds like my Ex-Wife,but she lives in New York:leaving
1 - 20 of 34 Posts
