============================FWIW: My Z06 ECU “took a turn” a few months back while cruising down the road. The DIC said, Service Brakes, then the car began to lurch, the check engine light came on, and the engine went into limp mode and would not even idle. We coasted to the side of FM 518. I had it flat backed to the local dealer and told them the symptoms and then said, the ECU has an issue. After a week and a half with their Corvette expert, and many calls with the GM engineers, they worked their way to the ECU and finally replaced it. The tech felt so bad he didn’t charge me labor to do it. I ended up with a new MAF, MAP, throttle body and ECU and a bill for $3500.
I hope yours goes better.
OMG, ROBERT!!!!! --- That story is horrible. $3500.00 WITHOUT labor charges????
I have horrible nightmares that don't go nearly that bad!!!!
●○● ~ Stay tuned. (and cross your fingers!!)
David
