crogan said:
Now, how do i open the side of the fuse with the wires so i can plug my wire into an always active energy supply between 4-10 amps?
thanks
I would strongly recommend that you tap into the Aux Power circuit. It has a 20 amp breaker and is powered 100% of the time. You will need to put an in-line fuse to protect your additional wiring and equipment, just at the point you tie in.
If the equipment is to be under the dash somwhere, I recommend connecting to the orange input wiring to either of the dash mounted aux power connectors. If you are installing somewhere else, it will be significantly more difficult or complicated to find good power.
Let me know If I can help more, I have a set of manuals at hand.
