Shortly after I last took my 05 SSR (automatic) out for the last time last season (live in Michigan) I went to move it over to the lift bay in my barn for the semi annual oil chage (I have 3 other "summer rides" and I try and take each one out every week as much as I can so only put about a 1000 miles on each one every season so I only change the oil every other year) and noticed what looked like to my surprise a puddle of oil under the SSR. Got it up on the lift and it had started to leak from around the oil pan gasket. There was plenty of oil when I drained it so since I never has noticed it before it must of loosened up just enough the last time out to start leaking so I caught it early. All the oil pan bolts needed to be re-torqued. First time I had an issue with any leakage with the SSR and I have had it going on 8-9 years now. So make sure when you do chage your oil (or if you take it some where to have it done) double check the torgue setting on the oil pan bolts.
