Although I am posting this data, it comes only as a result of lots of meticulous work by Dan O'Toole.
For those that don't know, Dan is also the one who is converting each chapter of "The SSR Experience" as I release it, from Microsoft Word format to Acrobat pdf format, so that the file is smaller and can be opened by folks who do not have Word on their computers.
Dan bought his 2005 6-speed brand new (ok, one of GM's technically used "show vehicles") just a couple of weekends ago, and rove it from the dealershp in Dallas to his home in Toronto, Canada. Before he made the trip to pick it up, Dan asked me if there was any testing he could do on the trip that would help the board get some useful data.
I asked him if he would be willing to do some gas mileage testing, using a strict procedure described in detail in a much earlier posting this spring (search for "mileage" or "4.56 gearng"). THat procedure ensures that the results are very accurate and very representative of real world gas mileage at 60 mph.
I asked Dan to do the testing alternating between 6th gear and 5th gear. The reason I did this is to try to get a feel for how much the gas mileage would suffer for anyone who does the conversion from 3.73 to a higher rear axle ratio. I need to explain beforehand why the results are so encouraging.
The Tremec 6-speed has a 6th gear ratio of 0.50 (i.e. engine speed is cut in half by the transmission in overdrive 6th) and a 5th gear ratio of 0.74. THis means that runnin gin 5th gear versus 6th is equivalent to running a 5.52 rear axle ratio!! THis is WAY, WAY beyond what anyone would actually do as a rear axle change. In other words, the results are going to be MUCH worse than what anyone would actually encounter in reality with any sensible rear axle change,
You might ask how it is even possible to run at 60 mph in 5th, when the engine rpm is going to be 48% higher than in 6th. The answer is that the stock gearing is pretty ridiculous. The engine is only turning at 1284 rpm at 60 mph. This is so low as to be labeled "engine abuse" for an engine that redlines in the area of 6500 rpm! I told the technical folks at the SSR Homecoming yetserday that they should be ashamed of themselves even doing that! (They grinned sheepishly). Because of that low rpm in 6th, 5th gear at 60 mph is only 1901 rpm, which is almost 300 rm LOWER than I cam currently running on my 2004 5.3 liter LM4-based engine, and I am getting 19.6 mpg right now on the highway even after my major mods at MTI this week (more power now at the rear wheels than a stock 2005 SSR that has 13% more displacement!). THis is nothing to cry about . . .
Dan, bless his heart, took me VERY seriously, and did LOTS of testing, even getting results with top up, top down, AC on and AC off! Here are the results of his hard work. Because this posting medium does NOT support tabs, I have had to use "/" as the separator, which makes reading the results a little difficult, but if you bear with it, this is a gold mine of impressive data.
6th Gear / 5th Gear / Notes / Mileage in 5th vs 6th
23.5 / 20.8 /No Air Top Up / 0.89
24.7 / 21.1 / No Air Top Up / 0.85
24.9 / 19.8 / Air / 0.80
24.5/ 19.9 / Top Up Air / 0.81
26.8 / 23.3 / Top Up Air / 0.87
27.1 / 22.7 / Top Down Air / 0.84
27.3 / 19.8 / Top Down Air / 0.73
25.9 / 21.1 / Averaged results for ALL of above / 0.82
Combined summarized results (all at 60 mph):
With the top up, but no air, mileage in 5th was 87% of mileage in 6th.
With the top up, and air on, mileage in 5th was 83% of mileage in 6th.
With the top down, and air on, mileage in 5th was 78% of mileage in 6th.
Overall average was that mileage in 5th was 82% of mileage in 6th
Total Distance Driven 1,550 miles
Average MPG for trip 22.81 (!!)
6th gear ratio =0.50, rpm = 1284
5th gear ratio =0.74, rpm = 1901
Difference =1.48
Running in 5th versus 6th is equivalent to a 5.52 rear axle ratio!
So, what we have done is "simulated" running a 5.52 axle ratio, 48% stiffer gearing than stock, on the highway! We have found that even that absurd ratio STILL gives you 82% of the gas mileage of the stock 3.73 axle ratio! And that includes running top down with air on for part of the averaged results!
Running a 4.56 axle ratio like I am cost me only an actual 7.4% drop in fuel mileage (My new mileage was 92.6% of mileage with stock gearing), nd I got all of that back via a good dyno tune at MTI Racing.
You guys with 6-speeds will NOT be hurt much in gas mileage by changing ratios to anything sensible (4.56 recommended).
A couple more explanations:
Gas mileage with the top down is worse than with the top up because of poorer aerodynamics with the top down.
Gas mileage with the air on is worse than with the air off because of the horsepower used by the air conditioning system to make you comfortable. The AC draws a LOT of power.
The loss in fuel mileage in 5th versus 6th is mostly because you are spinning ALL the accessories and the driveline FASTER for the SAME road speed, so you are creating proportionately more driveline friction and driving the AC, the power steering, the alternator, etc, faster than you really need to. You would recover most of that loss (all but the increased driveline friction) by changing to underdrive pulleys (ONLY after stiffening the gearing!! NOT with stock gearing!), as I did at MTI this week also (It was a BUSY and dramatic 3 days at MTI, but that's a separate posting I will try to post later today or Sunday).
And yes, the SSR routinely beats the EPA highway fuel mileage rating unless you have a lead foot.
Difference =1.48
