1 - 10 of 10 Posts
I noticed by accident a small glow of light coming from around my glove box when closed. The plastic light bracket had moved away from the contact point. I could have pulled it down into position, but I just decided to remove the bulb.
Another phantom draw eliminated ! :yesnod
:black: :smile2:
:black: :smile2:
If you decide to install a new one, let me know. I have a box of brand new ones that came from Floyd/ASC.....
Not if its made out of plastic like the original. Over time the plastic loses it original shape!
:black: :smile2:
I can mail you a new one, if you like. Maybe it's some defect with the one you have. Would be interesting to have a look at the two, side by side.
Cantankerous SSR CaretakR
Also check to make sure the glove box door is closing completely. The metal hoop that the latch engages is adjustable by loosening the two screws and then aligning the hoop.
Plus, glove box fuse, rear fuse box, is #40, same one that powers the Bed Light!
1. I would/urge change fuse 40 from 15amp 04, 10amp 05, to a 1amp or 2amp fuse.
2. As Gary aka river_rat said it is probably just the switch/door adjustment.
1 - 10 of 10 Posts
