Instructions - no pictures...
Service Information Document ID# 1202118
2005 Chevrolet SSR
Fascia Replacement - Front Bumper
Removal Procedure
Open the hood.
Remove the grille applique molding. Refer to Grille Applique Molding Replacement - Upper in Exterior Trim.
Raise the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
Remove the tire and wheel assembly. Refer to Tire and Wheel Removal and
Installation in Tires and Wheels.
Remove the wheelhouse liners. Refer to Wheelhouse Liner Replacement - Front in Body Front End.
Disconnect the front fascia wiring connector from the body side harness.
Remove the fasteners that attach the front fascia to the fascia support bracket.
Remove the side fascia attaching fasteners.
Remove the front fascia assembly from the vehicle.
Installation Procedure
Align the front fascia assembly to the vehicle.
Notice
Refer to Fastener Notice in Cautions and Notices.
Install the front fascia support fasteners. Tighten the front fascia support fasteners to 6 N·m (53 lb in).
Install the side fascia attaching fasteners. Tighten the side fascia support fasteners to 6 N·m (53 lb in).
Connect the front fascia wiring connector to the body side harness.
Install the wheelhouse liners. Refer to Wheelhouse Liner Replacement - Front in Body Front End.
Install the tire and wheel assembly. Refer to Tire and Wheel Removal and Installation in Tires and Wheels.
Lower the vehicle.
Install the grille applique molding. Refer to Grille Applique Molding Replacement - Upper in Exterior Trim.
Close the hood.
Other years should be the same.
Diggs
P.S. Pictures might be possible later, but I am at work and it just ain't gonna happen from here. :nono
