1 - 6 of 6 Posts
1st dealer says the burned out headlight needs an electrical tech to look at and change, second dealer says it takes 4 hours to change one! The owners manual makes it sound easy has anyone changed one?
Thanks for help.
There's a nut on the underside of the front fenders that open's a little door (compartment). You have to turn the wheels for better accsess to the side you need to work on. Changed both in about 15 min. The high and low are both in the same compartment. Just twist bout 1/4 turn to release bulb socket. DON'T TOUCH NEW BULB WITH FINGERS WHEN YOU REPLACE IT. Good luck.
Paul Perinati
Oh.....My.......God ! ! !
Thanks for help.
BAHAHAHAHAHAHAHA......Did he quote you any times to change oil, filter and lube her ? Like bring her in.....leave her 3 days and come pick her up..... :rolleyes:
Gary (WearyEagle)
1 - 6 of 6 Posts
