1 - 11 of 11 Posts
Seems like most top experts are in Florida, Texas or Arizona. Try to contact Dick, Dictator, in Florida. He wrote most if not all of the how to library. If he can't fix it he will definitely point you in the right direction. Good luck.
Send him a private message with your problem. Give him your phone and e-mail to communicate better and faster.
Joe were you able to get your information on the Top?
I'm not too far from you and would be happy to come give you a second hand. However I have not worked on the top before. Cant come this week as I fell and waiting on knee swelling to go down. Lol
I should be able to drive to Corinth next week if you need assistance
Discussion Starter · #6 ·
ok, cleaned and lubed micro switches inside tonneau cover on both sides. put bolts back in latches and just snugged them. had the cover up. When I pushed top up, it would time out. Pushed the top down, cover closed. pushed up again and i'm back to open tonneau manually. What's next?
What happens when you try to lower the top, DIC readings ? I am In Picayune. My phone number is 769-926-2389.
Go to this link, https://onedrive.live.com/?id=3EF39D9F5ADCE5E5!853&cid=3EF39D9F5ADCE5E5 Scroll down to "Roof Switch Failure Symtoms". Give me a call
Jack
Hey Joe,
Jack is the best. I drove my :yellow: from Baton Rouge to Picayune and in one afternoon we were able to take care of my roof: replace pneumatic cylinders (from Mike in Az), lube limit switches and remove main hydraulic cylinders. I sent the mains off to be rebuilt by Cabriolet Hydraulics in Florida and re-installed them myself. No problems since then.
Pat
1 - 11 of 11 Posts
