Hi All,
I am away from my Florida home for work in Missouri. I have my SSR with me and am experiencing a new problem (at least I can't find any similar issue on the forum). About 2 days ago the door locks on my SSR began "UNLOCK-LOCK'ing" themselves on their own while the SSR is in motion. It was a only a couple of times that first day. Yesterday it started doing the same thing, door locks cycle UP-then-DOWN while driving, but doing it more often ... about once or twice every 30 minutes or so. TODAY ... THE DOOR LOCKS WENT CRAZY and cycled UP-DOWN UP-DOWN about 15 times in rapid succession ... THEN ... I got a lightshow on the dash! The ABS light, the BRAKE light, and the Traction Control Light illuminated steady and would not clear. I also got the "SERVICE BRAKE SYSTEM" text warning on the DIC. I stopped the car, shut it down and restarted, and everything cleared ... at least for the next three minutes ... and then the door locks began cycling UP-DOWN again. When this is occurring, the little indicator on the DIC that shows the transmission setting (P-R-N-D-2-3) would move from "D" to "P" and back again; and the TACH needle AND Speedo needle would drop then return to normal indication. The engine is also hesitating when this is happening ... seeming to lose power then regaining power. It stumbled once during the door lock cycling. I then got the dash lightshow again with the ABS/BRAKES/Traction lights illuminated and steady. I am searching the forum but need some HELP with this as I am relying on this truck working while I'm away from home. Any assistance or recommendation is greatly appreciated.
Cheers, Carl
Cheers, Carl
