what do you need help with?my number is 910-640-8878
see this post for his problemMy number is 910-640-8878
I would start with the battery low amps can cause a lot of problems. If your battery is low the key will stick in the ignition.SSR died. Gauges started swinging, door lock going up and down. Cut engine off, now ignition is stuck and no electrical works.
Turned out to be a battery with a bad cell. It is being replaced. Nice when the fix is easy. His phone is nearly dead but he will be in Maggie Valley in a few hours.I would start with the battery low amps can cause a lot of problems. If your battery is low the key will stick in the ignition.
Also check out Dicktators library for more help https://onedrive.live.com/?id=3EF39D9F5ADCE5E5%21853&cid=3EF39D9F5ADCE5E5
