that's the upperr,don't have a link to the lower do you thanks, RobertThe upper and lower bushings are different sizes. See this link showing the two in the NAPA repair kit.
https://www.ssrfanatic.com/forum/f5/console-end-transmission-cable-209090/#post3517218
Autoprof, did you get the upper or the lower bushing at the auto parts store.I got mine at advance auto. Shouldn't be hard to find the right parts.
Here's a clarification. The kit part numbers are NAPA 615-1433 or Dorman 14055.that's the upperr,don't have a link to the lower do you thanks, Robert
Dictator, will you be bringing a shifter kit and heat shield with you to Warner Robins?It's on SSR How to Library including Part#s.
Look under UPPER SHIFT CABLE REPAIR
