1 - 20 of 30 Posts
Has anyone else had a problem with the Chevy insignia on the hood breaking. Had my oil changed last week and the mechanic broke it! Anyone have any ideas to prevent this?:black:
Discussion Starter #3
Deltona
Hey Poppa I too am in Deltona! Brought the truck into Boulevard Tire for oil change and the damn mechanic yanked the plastic Chevrolet bar off! They are ordering a new one, hope they can find ine. Have to say pretty poor design to make it out of plastic:mad
Get some "J-B Weld Quick" and just put the pieces back to gather with a big glob under each of the bolt pieces, works great and strong.
Actually the mechanic used JB Weld to try to fix it fell off in two hours after curing all night
He just did a crappy job. If you put a solid glob under the bolts, and not just a dab at each end, it makes the bolts a solid piece of the emblem......
and use the "Quick" because it is more of a liquid than the stick version. You need to make a dam on each side to hold the JB in place or it runs,
I put masking tape on one side and stand the whole piece vertical, the Quick will be hard in about 5-10 min.
observe photos of repair
I applied fiberglass and painted it with resin to beef up the rear of the trim piece. Especially the angles that are part of the screw attachment. That is a weak spot and needs reinforcement or it will be broken by most folks that grab hard at things without regard to the hood as they slam it shut. I posted photos of the repair I did, use the search engine to find a lot on this problem and the fixes.
Sorry
Boomer
Sorry, somehow I missed this thread , and your reply if you still have the parts I can give it a try to repair it to use for a spare for you. Send me a PM and I'll give you my phone #
Dan
Tech Support/Research
Hood Emblem
Although this won't help an already broken emblem, I make a point of lifting my hood by the two steel front hood edges, and tell any technician to do the same. I also advise not to slam the hood, just push it down to the catch and give it one more gentle push to secure it.
Discussion Starter #15
Thanks everyone, they found a new one and I'm all set. Already repaired the damaged one and now have a spare. Thanks again for all the great input!!
#1 SidePipe Club
Closing the Hood.
"Although this won't help an already broken emblem, I make a point of lifting my hood by the two steel front hood edges, and tell any technician to do the same. I also advise not to slam the hood, just push it down to the catch and give it one more gentle push to secure it. "
I go one more step, I carry three peices of blue masking tape with "DO NOT USE TO OPEN !" that I put on the hood emblem, and two that say"HAND HERE TO CLOSE !" that I put on the hood edges. I put these on the hood each time I take it to the dealer or for service. :black:
1 - 20 of 30 Posts
About this Discussion
19 Participants
Antique
Chevy SSR Forum
Full Forum Listing
