I had the hood up on my 04 and it has the ball sockets for the Strut rods but yet I have the prop rod. So has the hood been changed and is it from an 05 or was this a mid year change on the hood? I am going to change it over to the struts with the kit, will these balls be in the correct location for the strut kit?
Yes, you have a 2005-06 hood on your 2004. No big deal.
Struts and the hood mount position are the same for the 2003-04 and the 2005-06. On the hood, the OEM ball size is 8mm and we changed the LST to match that about a year ago. Made my life a lot simpler. Older retrofit installations of LST struts on 2003-04 had 10mm ball ends on the hood brackets that were riveted on.
We can come up with a partial set of strut mounts for your truck, if you decide to install the pneumatic struts and toss the prop rod. Just put the note in the comments section of your order and I'll call you to be sure we are on the same page.
Regards,
OH....And thanks, Dwight for watching my back....:nerd:
