From the EFILive tuning software "help" screen relating to engine cooling fan operation:
Select the type of cooling fans fitted to the vehicle, the PCM supports the following types -
1. Series Parallel Fans - Where both Fan Outputs (1 & 2) are used to control two fans.
2. Auxilliary Fan - Where just Fan1 output is used, generally these vehicles will also have a mechanical clutch fan.
3. No Fans - Only a mechanical clutch fan is fitted
4. EV Fan - Used on later model vehicles, the fan speed is variable by means of a PWM output.
Only the following values may be entered for this calibration:
- Series Parallel Fans
- Auxilliary Fan
- No Fans
- EV Fan
So, those of us seeking better engine and underhood cooling may have a fair bit of flexibility . . .
mikem2005: I figured you would appreciate this info.
- Auxilliary Fan
- No Fans
- EV Fan
