Need a mechanic to repair my 2004 Retractable top. Got two Lift cylinders leaking. Dealership wants 7000 to repair. Anyone in North Carolina that can repair.
Was that cost for all new parts. If so how can they give you estimate on parts that are not available. See your new member. Welcome to the forum from middle Tn.Need a mechanic to repair my 2004 Retractable top. Got two Lift cylinders leaking. Dealership wants 7000 to repair. Anyone in North Carolina that can repair.
I suspect the $7000 quote was to scare you away or settle for a low trade in value.
Do some reading, find some members close who can help, and you can probably get away for $1500. $1000 to rebuild the 8 cylinders and $500 for food & beer. :lol
$7000 to repair the 2 cylinders (or is that for all 8?) Either way that is outright THEFT! Get a local Fanatic to assist you in removing the cylinders and send them to Top Hydraulics in Oregon. Top Hydraulics will send you a full replacement set, when you trade-in your leaking set, for $1000.Need a mechanic to repair my 2004 Retractable top. Got two Lift cylinders leaking. Dealership wants 7000 to repair. Anyone in North Carolina that can repair.
Have a Fanatic friend that's done several top cylinder changes and says he does not dimple the metal.Carlbush....is it necessary to beat down the metal under the roof lift cylinders?
Short answer ... in my experience, YES.Carlbush....is it necessary to beat down the metal under the roof lift cylinders?
Hate to disagree, but I just watched the Top Hydraulics video and they DO show dimpling the metal. They also state that the actuator can be removed by twisting it off the lower pin, but I have witnessed the lower pin sleeve get damaged by twisting it off the pin (the pin binds against and tears the plastic sleeve as the actuator is twisted).Top hydraulics video does not show dimpling the metal but I’ll admit it is easier to dimple it somewhat.
Every installation is unique due to the variability in body fit and placement in our trucks.Hate to disagree, but I just watched the Top Hydraulics video and they DO show dimpling the metal. They also state that the actuator can be removed by twisting it off the lower pin, but I have witnessed the lower pin sleeve get damaged by twisting it off the pin (the pin binds against and tears the plastic sleeve as the actuator is twisted).
video link below - start at 5 minute mark:
Top Hydraulics video - Ch-5 - Main Lift Cylinder Removal
If you can make it to Warner Robbins, Georgia for the rally next week, there will be a number of us that have done the swap out and willing to help. I'll bring the limited number of tools required and the steel rod to dimple the metal. It would be a great way to meet a lot of other SSR owners.Need a mechanic to repair my 2004 Retractable top. Got two Lift cylinders leaking. Dealership wants 7000 to repair. Anyone in North Carolina that can repair.
You also need to suck out all the old hydraulic fluid and add fresh CFH 11S because the old fluid is 14 years old and contaminated. OReillys usually has it on the shelf or can have it in a few days.
Greg
