Movie link
By replacing the gas springs with stronger ones my hatch pops open reliably. The down side, it's not easy to close, with one hand.
The stock struts generate ~67lbs force each, the replacements generate 100 lbs. I tested the hatch with one of each installed. That would be 167 lbs lift. It was an improvment but not fully succesful. With the tail gate open it popped, but not when closed. After both were installed, 200 lbs lift, the hatch popped reliably even with the tailgate closed. I suspect two 90 lb struts would work.
The struts are also 7/8 inch longer when compressed. That makes the struts 5/8 inch too long for a simple replacment. I had to remove the pins from the hatch and replace them with new ones located farther back. The pins are riveted in place and have to be ground out. Mounting the new pins requires drilling an 11/32 inch hole 5/8 inch aft of the original pin location. The replacment pins simply bolt in.
I bought everything from McMaster-Carr
I used:
2 - Gas Struts 100lb P/N 9416K346
4 - End Caps P/N 9416K86
2 - 10mm Ball Studs P/N 9512K63
4 - 5/16 Washers
2 - 5/16-18UNC Aircraft Hex Nuts
P.S. Cost for the parts $30.22 not including shipping, or washers and nuts.
Edit: That is 11/32 not 11/16. BIG difference.
I used:
4 - 5/16 Washers
