I just got back from an arrand into the city, and got concerned that maybe the engine cooling fan had failed again.
With my reprogrammed PCM, my engine coolant temperature gauge normally does not ever rise above 210, but this afternoon it started rising above that whenever I was stopped and idling, hitting the end of the "0" in the "210" label, and maybe a bit beyond.
This looks like the same synmptoms I had when the high-speed failed and only the low speed was working on the fan.
But, when I got home I checked the actual ambient air temperature on the web. In Austin right now it is 106 degrees!! (That's one hundred and SIX, yes)
So, maybe the SSR is entitled to a bit of extra slack today . . .
