Ok, so I'm a little confused with the directions on how to replace the ignition switch directions....
The pictures and the directions are a little off, or I'm reading them a little off.
On slide (1) it states to turn key to RUN position; but isn't the picture showed the switch in the OFF position? Which is accurate?
On slide (3) it states to remove the tilt wheel selector. Is there a clip to remove or do you just pull in it (towards the drivers door)?
On slide (16) it states to push until against spring position. Does it mean to push DOWN on the great teeth or to push the gear teeth UP clockwise/counter clockwise?
Any insight on this would be very helpful. Thanks!
