I have just returned from the dealer and I think we have solved the "tink" problem. They figured this out on on of the Trailblazers and so far it got rid of the tink on mine!!!
On the rear of the driveshaft when it gets shipped there is a strap of metal that is put in to keep the u-joint cups from falling apart. This strap was left on when the new driveshaft was installed. When it is in place it hits on the center of the u-joint when there is movement. Removal of the strap has stopped the problem, at least for now. Hopefully it will be a permanent fix.
This would also be the reason why some of the replacements would tink and some wouldn't.
I'm attaching pics. The first is a shot of the u-joint with the strap still in. The second is the strap. The third is of the u-joint with the strap removed, The bolts still have to be tightened.
