1 - 20 of 36 Posts
Does anyone have the following for sale? They were discontinued in 2009.
GM Part #15829007 LH SEALING STRIP FRT S/D WDO OUTER (BELT MLDG)
GM Part #15829008 RH SEALING STRIP FRT S/D WDO OUTER (BELT MLDG)
These are the rubber sealing strips that are on the outside of the door window glass.
Skip
They have been discontinued a number years. Pull the inside panel. Remove or clean the old material , apply adhesion promoter the apply soft 1/2 of Velcro trimmed to fit. Just like what Dictator shows on the inside for tinted windows. MOLE SKIN FOR TINT WINDOWS 82019.pdf - OneDrive (live.com) He has updated and recommends soft side of Velcro.
Jack
Discussion Starter #4
Jack
That is not the strip I'm talking about. It is on outside in the body of the door. I'll post a photo.
I can mfg / extrude that in silicone
send sample
I will return two for you with clear silicone cement
Regards GB
Discussion Starter #10
send sample
Regards GB
Thanks for the offer. I have located them but a little pricey for me.
I am going to remove these on a warm or hot day. Clean them and reinstall stretching them as I reinstall.
@GB92270 Looking at a picture of it, it looks like it is not just a straight piece. It looks like it has another section off of it, as well as it looks like it maybe different on the ends. Can something like that still be done?
590873
Discussion Starter #14
It has to be molded not extruded. I think that’s why it’s called molding.
That’s a molded assy
If this group does not get together and do a group buy and all share the tooling, it will never happen.
Use silicone only
Discussion Starter #16
Use silicone only
That sounds good to me as long as it is black not clear.
Thanks to all.
Is anyone else have the molding shrinkage problem?
Silicone can be any color
I mfg four shades of door seals for the
55 thru 57
Sl300 and Roadster Mercedes Benz
Iam a proud owner of a silver 56”
Skip
Wild bills ssr
1 - 20 of 36 Posts
