Some of you know that I am doing the research that needs to precede a change I am planning in final axle ratio. I did some testing early this morning that generated results that are very encouraging.
By way of background, the SSR comes with a 3.73 rear axle ratio, which sounds "aggressive", until you remember that the weight of an SSR with NO options and NO fuel or driver aboard exceeds 4800 lb. With that kind of weight, 3.73 is not aggressive at all, but actually not enough. I will prove that in a separate posting on gearing.
In this posting, I address the question of "how much gas mileage do I lose if I change the gearing to an even higher axle ratio?"
In the past ("the good old days"), a competent mechanic would tell you that increasing axle ratio appreciably would improve acceleration performance notably (not just under hard acceleration, but also responsiveness at part throttle) but would really hurt your gas mileage.
A theoretical physicist would have objected, saying that work done to oversome wind drag and road friciton.
=rpm x torque actually needed to overcome wind drag & friction
is the same whether you use more revs and less torque per revolution, or more revs and less torque per revolution.
The mechanic would point out that there are 3 flaws in that theoretical approach:
1. A number of accessories on the engine run at engine rpm regardless of actual load, so the power consumed to drive them goes up with engine rpm even if the external drag loads on the vehicle are the same. So, more rpm at the same road speed means more power lost to drive these accessories.
2. Certain driveline frictional losses go up with rpm. So, more rpm at the same road speed means proportionately higher friction losses.
3. Carburetors (this was before fuel injection!) work in an inefficient manner that causes fuel mileage to drop if the bores are opened either too much or too little compared to the narrow range they were tuned for. Remember that carburetors did NOT "calculate" the real amount of fuel needed taking into account all variables, but rather were "mapped" by trial and error ONCE at the factory, AND used primarily air venturi effect to draw fuel into the air. (VERY "approximate")
The physicist today would say that 1. and 2, still apply, but fuel injection works WAY better than carburetors, if the fuel injection is mapped at all decently, because it actually has a computer that calculates the ideal fuel amount needed many times per second.
So, I did an experiment this morning.
I ran the SSR on crusie control at 60 mph, changing between overdrive and 3rd gear every 3.0 miles, first northbound and then soutbound (at a time when wind velocity was officially reported at "1 mph or less" anyway), on a hilly divided highway.
Now, 3rd gear is a 1.00 internal transmission ratio, while overdrive 4th is 0.70, so running in 3rd simulates a 43% change in rear axle ratio (!!), or in other words it simulates running a 5.33 axle ratio! I was at 2600 rpm at 60 mph when in 3rd!! In other words, this simulation is absolutely the WORST scenario anyone could picture in terms of losing gas mileage, and far worse than what a 4.11 (10% ratio change) or 4.56 (22% ratio change) would do to your mileage.
For each 3 mile test segment, I did the following:
- Select either 3rd or 4th gear
- Reset trip meter to 0
- Reset cumulative (not instant) MPG
- At 3.0 miles, note and record the cumulative MPG reading
- Repeat for each 3 mile segment (I did a total of 16 segments, or 48 miles, to average out hills)
The result was VERY interesting:
Average MPG for 4th gear: 22.8 (yes, that's not a misprint, 22.8)
Average MPG for 3rd gear: 19.0
Difference (absolute): -3.7 mpg
Difference (percent): -16%
By way of confirmation for skeptics, MTI Racing, who I discussed gearing changes with recently, reports that on C5 Corvettes with automatic, changing ratio from 2.73 to 3,73 (a 36.6% change!), which they RECOMMEND to C5 owners who are willing to listen, typically drops the MPG from 25 to 21, or 16%.
So, I figure an actual change in ratio to "only" 4.11 or 4.56 will cost me far less than the 16% loss with the whopping 5.33 simulation! I figure maybe 8 to 10% range, which I can live with if it gets me better throttle response.
As you will see in my upcoming "gearing" posting, the improvements created by by changing to either 4.11 or 4.56 are staggeringly good.
Stand by for more. . .
