Installed the repair kit on the inside drivers side still won't work most of the time
any suggestions ?
any suggestions ?
Had this happen recently, SPRAY/LUBERCATE door module at door latch.Installed the repair kit on the inside drivers side still won't work most of the time
any suggestions ?
It could be that rod needs to be adjusted (shortened). This can be done by slightly bending it.Been there done that if the door is not shut all the way it will open from the inside
and i did put the repair kit on
thanks
Yes, this happens when handle is Pulled and Pulled and won't open.It could be that rod needs to be adjusted (shortened). This can be done by slightly bending it.
If you pull "toward you" it will make the throw longer which is what it needs to be.Make it longer or shorter ?
Thanks for any help
have a great day
