1 - 2 of 2 Posts
I am currently installing the dynatec headers on my 2004 SSR. I have run into a problem and was wondering if anyone has a solution.
When I installed the passenger side header (the spark plug closest to the firewall )when you attempt to put the spark plug wire back on it will no longer fit with the metal covering that covers the boot, it will fit if you take the metal cover off?? all the other plug wires work fine with their original covers does leaving the metal cover off cause a problem
Think You Have The Metal Gasket On Wrong- Take It Off And See If The
Small Lip Isn't Creating Your Problem-same Thing Happened To Me-everything Will Fit Properly When The Gasket Is Installed Correctly
John
1 - 2 of 2 Posts
