In search of the intake hose clamp. The one near the engine. But if you have both i take it too
I don't think either one of them is correct. I just had mine off and I noticed that the rear clamp has the notch for the back of the duct. Those look like the front clamp with the slot and hole for the front of the duct.
Hey @HUAWI believe I have one. I can check my little stash tomorrow. I see you are in Puerta Rica but I'm sure I can get it shipped there. Send me a " conversation" and we can work out the details if I have one.![]()
Yes it would, and you’ve have to cut the notches off the rubber, which is no big deal.@Ruben, and others. Wouldn't a regular worm clamp, worked over with a dremel tool, to make / cut, the notches work? I haven't looked at them close but seems doable? Also could position the screw at any position you wanted.
YES I THINK IN THAT OPTION IF I DONT FIND AN ORIGINAL.Yes it would, and you’ve have to cut the notches off the rubber, which is no big deal.
Be careful with cutting the rubber.Yes it would, and you’ve have to cut the notches off the rubber, which is no big deal.
