From Wiki:
A roadster, also known as a spyder or spider, is a two-seat car, traditionally without either a roof, side or rear windows.
Most modern day two-seaters have windows and feature retractable roofs (and are thus convertibles). While retractable soft-tops are nevertheless marketed as roadsters/spyders, retractable hard-tops are commonly designated as coupe roadsters.
A truck (US) or lorry (UK) is a motor vehicle, more specifically a commercial vehicle commonly used for transporting goods and materials. Some light trucks/lorries are similar in size to a passenger automobile. Commercial transportation trucks/lorries or fire trucks can be large, and can also serve as a platform for specialized equipment.
A pickup truck (or pick-up truck or simply pickup) is a light motor vehicle with an open-top rear cargo area (bed) which is almost always separated from the cab to allow for chassis flex when carrying or pulling heavy loads.[citation needed]
Several North American vehicles, the Chevrolet El Camino, Ford Ranchero, and Honda Ridgeline and Subaru Baja have beds, but are not technically trucks[citation needed]. Although the El Camino and the Ranchero were built with body-on-frame architectures, they were based on existing station wagon platforms, while the Ridgeline uses a spot welded sheet steel monocoque (unibody) chassis in the same style as modern passenger cars. Trucks typically have either a tubular or channel rail chassis with a fully floating cab and separate cargo section to allow for chassis flex and prevent warping of the sheetmetal. The sheet steel in both of these sections is not a stressed member. A combination of the two styles, monocoque cab and engine bay welded to a 'c' section chassis rear is offered in Australia. It is known as the 'one tonner' because it is rated to carry some 250 kg (551 lb) more than the all monocoque style.[citation needed]
Vehicles like the Holden Ute and FPV Pursuit, colloquially called a ute or utility (from "Coupe utility") in Australia and New Zealand, are known in South Africa as a bakkie (pronounced "bucky"),in Romania as "slipper", in Egypt as "half truck", and in Israel as a tender. Panel vans, popular in Australia during the 1970s, were based on ute chassis; known in Egypt as "box".[citation needed] Coupé utilities and panel vans usually have an integral cargo bed behind the cabin with unibody or monocoque construction like automobiles.
The design details of such vehicles vary significantly, and different nationalities seem to specialize in different styles and sizes of vehicles. For instance, North American pickups come in full-size (large, heavy vehicles often with V8 or six-cylinder engines), mid-size, and compact (smaller trucks generally equipped with inline 4 engines).[citation needed]
I'd say it's neither. Or maybe a "coupe utility roadster" (and a mouthful).
But it sure is a lot of damn fun.
(I can, and do, pull a utility trailer, too, but so can my Honda minivan.)
