1 - 20 of 20 Posts
I feel anytime you have to jack up any vehicle, their is always a danger to it. Of course when I was young, didn't think a thing about it. I'd put that 55 Chevy up on "wooden" boxes if I thought they would hold "her" Now that I'm many years older I really care about my fingers, feet and of course my life. Sorry I'm not much help. tennesseecozydog :ssr
Addition --- come to think of it, they were World War II wooden ammunition boxes Dad got at the Army surplus store.
Discussion Starter · #5 ·
I've done the side lift a few times with no ill affect. Just make sure the stands are of high weight rating and I always leave the jack up and locked as well.........
Thanks
Just got the stands yesterday and they're rated for 2-ton ea.
It seemed like I might have been putting a big strain on something on the other side.
I don't t know, bearings or something :confused
It's a lot more scary going under there than it was 50 yrs ago :surprise:
Yea but look at all the money you're saving not having to invest in a bunch of stupid jacks and jackstands.
That way your family can use the money for your funeral. Very considerate don't you think?
I lost a friend back in the 60's. Young and clueless. The rear crushed his head. When in doubt I use the junk yard back up method. I stack filled wheels and tires under the vehicle as back up for the jacks....stands. Then shake the vehicle hard..........Also can rest on the tires and remove the jack stands...........As one said, always leave the jack in place.
Birdmans
Discussion Starter · #16 ·
Done and Done !!
Still alive after installing the ABS Heat shield and the "Dicktator" shift kit. (Good thing the nylon bushing crumbled)
Tuffest part of the job was getting on and off the kreeper. Since when did THAT become an Olympic event ??
BTW the jack stands are 6 ton ea. Don't know how I wrote 2 ton.
Now off to replace radiator bracket and cross arm
Daily Driver
Silver Bullet, I'd suggest putting the top up first. I've no proof but I believe it would make the truck less susceptible the bending and twisting. Can't hurt. ;)
if you are going to use jack stand why not go for more height??
Used to put buses 30 footers 40 footers and even articulated coaches up in air on jack stands in air using tall jack stands. Tie down complete rear suspension and would install new stuff , remove transmissions too. Even simple services
1 - 20 of 20 Posts
