1 - 20 of 20 Posts
Trygodfirst
2006 FPR ROTM WINNER SSR PAC BLUE AUTOMATIC -aka- Ole Blue
today our PAC Blue comes home and heads for a proper front end align and road force balance. Then a proper paint correction and Lord willing xpel paint protection. Then after I pay off what I lost below a spoiler like I had on my 03 ssr and Mike’s exhaust tips
Here’s what took so long to do but it’s behind me now.....
CK = DONE
TRICKY FUSE BOX HAS DEFECT I HAVE ONE THAT IS ALREADY FIXED HERE .
WE MUST SWAP ASAP MUST SEND MY ORIGINAL FUSE BOX TO @Dicktator
Ignition control switch
Install new seat covers
Two metal bushings on top hinges
wiper blades you supply
redo wiring of top hinges removing metal ties and wrap and secure with tape
ck. for proper hydraulic fluid and leaks in top hydraulics
Use sponge and cut to fit vents to outside top storage area behind cabin
Lithium grease all top hinges
Lithium grease door and cargo hinges
Lithium grease shafts of hood and rear cargo struts
Lithium grease hood latches
treat rubber moldings for top, doors, cargo/trunk
Spray electric CSC on ALL micro switches
No need for plugs or wires at this time
install new coolant overflow tank and its new cap
new thermostat and gasket
upper and lower radiator hoses
Install new heater hoses
flush cooling system add new fluid YOU SUPPLY
serpentine belt u buy
power steering belt u buy
NEW BLACK POWDER belt tensioner
ck. for loose harmonic balancer/guys reporting a bolt is backing out
some have replaced with fluid damper type others fixed problem with bolt
INSTALL NEW black Powder alternator SAVE ORIGINAL.
Install chrome and red SSR letters to hood blanket
Install blue SSR center insert to engine cover
A/C system ck all/service. I admit it blows very cold as is/small drip passenger floor
ck and change air filter as needed/clean its housing
engine oil is alread done
install new internal radiator fan
install metal lower radiator support
add new external tranny cooler
add new front external pusher fan READ INSTRUCTION REF TEMP/FAN SETTINGS
Install new front fascia (spelling) support brackets
INSTALL NEW FRONT AIR SPOILER save original. Add facia supports.
clean/polish black plastic FRONT license plate holder. Mount same WITH new chrome ssr image chrome plate
Install new chrome /black powder font grill inserts(3) SAVE OLD ONES
COMPLETE set of new led lights to include flasher module, rear carg,,vanity mirrors in cab, glove box. SPECIALNOTE HEADLAMPS
UPPER AND LOW BEAMS The front center piece of led lamp MUST be in proper vertical reference position (verify this)
Be POSITIVE to change cargo light fuse to 2 amp
IF IF IF FRONT OR REAR BUSHINGS LOOK WORN OUT INSTALL MY NEW RED NEUOPHREME ONES IF NO WE'LL DO LATER
Question, how difficult is it to change the rear bushings to new red neoprene ones(since were doing rear control arms call me
If above existing bushing are ok we can change them when my Bilstein shocks come in January 2021
Shifter linkage repair w/ metal bolt/nut
Install Heat Shield under car to protect ABS module from Cat Convertor
Install new oil sending unit.
Install new C06 oil pan
Install new heat blocking matting under cab of truck
install new tranny pan(I HAVE) and change filter and fluid, I have tranny pan u supply fluid and filter
ck and replace rear negative battery cable/seal with your magic corrosion stuff
Install a new INTERSTATE Battery please
ck front and rear brakes& rotors if need TO replace use heat dissipating rotors& QUIET ceramic pads/ I wont be towing
install new braided aluminum brake lines front rear I have
Flush all brakes lines and add new fluid
Install new rear diff. cover INSTALL NEW FLUID
Install new red rear heavy duty upper and lower control arms
add tire pressure monitor system
Mount mud flaps
Clean/polish and install rear license plate chrome piece
Install new front stiffener plate
Install new heavy duty rear cross member
Install new front cross member
God, family, church, retired
Trygodfirst
Discussion Starter · #2 ·
CK = DONE
Mount mud flaps
A special thank you to @Mike in AZ and @Dicktator and @HUAW and Phoenix Tramissions for all your products, advices, patient answers to my questions and for being there if my mechanic had a question. And Larry aka @HUAW for being such a kind and special person and fellow Blues Brother.
We owners are blessed to have ALL OF YOU in our ssr lives.
Sincerely,
Scott Harris
Sincerely,
Scott Harris
AMEND!
Now the real fun begins, get out there and drive it, enjoy the people asking questions, and prepare to smile and wave a lot.
Ah yes... And so goes the life of a retired, obsessed SSR owner. Just one question, what took you so long??? :LOL:
SSR Believer
WOW! o_O Excellent work Scott! In fact that's a pretty good "To-do" list for anyone that's wondering what they might need to check, work on or otherwise think about doing to a recently purchased SSR. Not saying all or even any of those things will need repairs or replacements, but a deep-dive and some preventative maintenance if one were so inclined.
I can't believe how many of those things I've either done myself or at least checked on over the past couple of years.
Nicely done and as @Stlhotrod said, now the fun begins. (y)
Attached a printable copy for anyone that wants it...
Trygodfirst
Discussion Starter · #7 ·
and now for a Marina visit permagrin back on
Perfectionist
Man, you did alot!!! Nice job!
Trygodfirst
Discussion Starter · #12 ·
our first cruise since mid October 2020
Lunch at Sailfish Marina Singer Island Florida
View attachment 594134 View attachment 594135 View attachment 594136
It’s has the 3ss chrome package. Went from chrome gauge trim to pacific blue. Added tire pressure monitor system. Changed out the chrome center console where the shifter and buttons for windows are after getting blessed to find a brand new still in gm box chrome one. The original one had a few scratches. I’ve saved BOTH factory original ones as spares till a day come when we sell her.
Trying to decide when I’ll enter her in the ROTM competition.
@Trygodfirst That is an impressive list, was it mostly just what you wanted done so you were ready to go with out any worries, or was some of it needed maintenance and upkeep?
I know for my trucks they all had a needed list and a when I get around to it list. Some how my lists never get completed.
Trygodfirst
Discussion Starter · #14 ·
I owned a low mileage 2003 Redline Red. @Klondike owns that one now. I did most all this to that one as well. Wasn’t the mileage but the age of our trucks. I knew somewhat less about our 2006 Pac Blue and being 15 years old... well, Rally in Ohio coming and I’m 14.5 hours and 905 miles away . Hard truth I guess is I hate breaking down. I am / was a fire science engineer and owned a company responsible for keeping my clients fire alarm system inspected and maintained to NFPA Standards and this mentality has fallen over to my personal life in all aspects. AC in condo serviced every 6 months, filter changed every month and on and on. Hurricane windows. Back up generator. The list is long but distinguished as he said in TOP GUN.
I remember reading on this site prior to our first SSR @Dicktator saying it’s not if it’s when an ignition control switch or shift linkage will fail. That’s all I needed to read. As you see the list attached also takes into account heat and noise dampening and a focus on under ssr handling items that simple engineering sells. I even had dictator send me a fuse box repaired JUST IN CASE mine had and issue. Turned out it was fine.
Guess this sums up my answer. Still have new Bilsteins to go and with just under 50k miles I’ve got a little time for those and plug wires and coils
( although I carry a spare coil) I will be going to NGK plugs when Jeremy here in Florida does the CPU tune. Jury out on yes or no on new exhaust tips.
Thank you for your question. 👍
Trygodfirst
Discussion Starter · #15 ·
First evening top down cruise tonight along the coast.
Trygodfirst
Discussion Starter · #17 ·
To each their own for sure as we all make our SSR’s our own. Here’s a couple pictures of a few upgrades. Doing all I can to prevent rocks being thrown up on paint. Mud flaps and running boards in place.
CK = DONE
Mount mud flaps
I’m tired from just reading the list !!!
Since I was the fortunate buyer of Scott's '03 RED R, I can tell you personally he is not blowing smoke!! 👍 He does it right or doesn't do it at all...👍 And, I feel very lucky to own his former '03 (all his work and parts, plus the truck only has 27K miles on it - NICE)! And, if you think his R is done right, you need to meet Scott in-person because he is as FIRST CLASS as his Rs - couldn't be a nicer person! 👏 😎 🇺🇸
Trygodfirst
Discussion Starter · #20 ·
Love you brother
Reactions: Klondike
1 - 20 of 20 Posts
