1 - 20 of 39 Posts
In fact, my Chevy Dealer Service says that GM's official position that anything over 800 miles per quart is nothing to worry about!
Thank God! My 1 quart per 1000 miles was starting to worry me! It's a big relief to here that!
What are you saying????
Are you saying it is normal for a vehicle to burn one quart of oil every 1000 miles? This is the first I have heard of this. Is anyone else as surprised as I am????
But Fords Burn 2 quarts....
Oh No...:willy:
RickSSR :cool
Quart every 800 to 1000 miles
If I were you I'd be looking at another dealer repair place. There is no way a new vehicle should burn 1 quart of oil every 800 to 1000 miles. You need to have your "heads" examined.
Oil consumption on my 6.0L
dougnc-
The dealer probably also thinks it has a 2 stroke motor and should burn that much. :lol
Burning a quart of oil in 1,000 miles may be normal for a 4 stroke motor after 150,000 miles on it or if you have been making full throttle 1/4 mile runs for some of those miles. Mine has burnt about 1/2 a quart in its first 3,000 miles and I hope it is just due to break-in and quite a few full throttle events now. If in my second 3,000 miles it burns half a quart I would think that was excessive too. I would expect more like a 1/2 quart of oil burnt between oil changes per the DIC, and that would be about 8,000 miles and after the first oil change.
Thats my 2 cents.
Doug
Machell
I would go to a different dealer, or call the GM Hotline!!! I have over 50k on my tahoe and it nevers uses oil between changes!
My GM cars have never used oil between changes though I do know that sometimes it does happen (I think Dodge had a major problem for a few years) and that some advertise that it is okay for up to 2 quarts between oil changes. On new engines it's mostly due to too much slack in the piston bore area that causes an issue with the oil rings.
Is it a real probelm? Maybe. There could be alot of factors that affect oil consumption. Here's a post about a problem that the Corvette Z06's had awhile back:
http://www.c5registry.com/2k2z06/page5.htm
:seeya
I think he is refering to the oil he uses in his hair. In which case, yes! this makes perfect sense. :cool
G.M. say 1qt for every 2000 mile is normal. have youe dealer look up bulletin #01-06-01-011B this will explain oil consumtion. I'll see if I can post the bulletin but I know enough about computer to get into trouble.
I agree with C1Trob on this one, Get a second opion. I can't believe that is "normal" . And being a new engine,No Way....
Now U Sound @#$##@
My 2005 with 3400 or so miles never had to add a single ounce ...............get it FIXED normal my @#$#
Growing Older but Not Up
Its Normal for a Service guy to make stuff up when they don't really know what they're taling about
WOW!!! engines should not use that much oil ,during break in ,a little ,during break in on a 2 stroke maybe that amount! there also should not be a "normal seapage amount"the oil is supposed to stay in the engine ,thats why they call them seals!
:ssr
Discussion Starter #19
:seeya
And the article clearly says that over 800 miles per quart is not a problem.
"Other customers say, ‘No. That’s why I bought my ‘Vette. I’m gonna drive it the way I wanna drive it.’ If so, that’s fine. If you’re getting 500-800 miles per quart, that’s too much and we’re going to swap the rings out in that engine."
You have a problem. When the LS1 first came out a lot of them had this problem (CAMERO) not anymore. That dealer is full of BS!!!!!!!
1 - 20 of 39 Posts
