Took the :ssr in at 7:00 a.m. today, one week since I got it back from the cooling fan being fixed with the check engine light on. Was ready by the time I got off work at 2:30...work order reads:
CUST STATES CHECK ENGINE LIGHT IS ON
1202 REPAIRED OPEN CIRCUIT IN SIGNAL WIRE
492. CLEARED CODES
SCANNED COMPUTER SYSTEM, COUND (FOUND?) MASS AIR FLOW SE NSOR CODE. CHECKED POWER AND GROUND TO SENSOR, CHECK OK. FOUND OPEN IN SIGNAL WIRE CIRCUIT 492 BETWEEN ECM AND MAF SENSOR. REPAIRED HARNESS AT MASS AIR FLOW SENSOR YELLOW WIRE CONNECTOR. ROAD TESTED AND CLEARED CODES.
Does this mean that possibly someone forgot to reattach a wire after fixing the cooling fan issue last week? Or could this mean something else entirely? Didn't have a chance to meet with tech today.
Thanks
Randi :seeya artsmart
P.S. drove home nicely although it had been sitting in sun so long that it took 20 miles to cool down somewhat...hot, humid day!
492. CLEARED CODES
Thanks
