Well it took 19,103 miles, but the inside door handle on my SSR finally failed today.
I got two "warnings" in the 5 minutes prior to the ul;timate failure, when it took 2 tries to get the door open. The 3rd time, it felt obviously borken, and would not open the door.
I did the "Brititsh sports car thing": Rolled down the window, and opened the door by grabbing the outside door handle.
Tomorrow morning, I call my favorite service advisor down at the Chevy dealer and ask him to order the parts for BOTH the driver's door and the passenger's door!
Here are the notes I copied and saved from prior postings by others here on this problem:
Door handle NEW part numbers
The parts ordered to repair my drivers side inside door handle was canceled by GM. Word is they needed to order different parts, as a set, to repair the drivers door and replace the part in the passengers door. The parts were overnited, arrived today, and have been installed.
For the first time in almost 2 months, I can use the inside handle to open my door.
I do not have photo's, but the hinge point on the new ones are more than twice the thickness of the old ones. Still a poor design and will probably break again, but maybe will last longer.
New part numbers were 15841788 and 15841790.
If your inside handle is broken, the dealership can order these parts. They will be shipped. If you are in or near Houston, my dealership is now experienced.
10-24-05 update:
Guys,
My door handle broke last Wednesday. I called my dealer armed with this thread and told him what was wrong. I also mentioned making sure that I received the correct year door panel. He told me that the door panels no longer need to be replaced to fix this problem. There is now an easy fix kit they can order to correct the issue. He ordered mine and had it the very next day. I asked him about the wait time some of you have and he said the dealers must not be keeping up with TSB's. Sorry guys, but I would make sure your dealerships are ordering the quick fix kit!!
So, is the 10-24-05 still the latest upate on this problem and its solution?
Are the two part numbers: 15841788 and 15841790
Still the correct ones?
10-24-05 update:
Guys,
