Ordered new key fobs, apparently they can’t communicate with the truck. Any thoughts on what to check 🧐 I hope I don’t need a new BCM. Everything else seems to be working. Thanks guys. 😎
It “could”, but should not. It would likely depend upon how the radio was installed and if there was some fiddling with the wiring harnesses. For the record, modules can be purchased to interface with the OEM connections, from Crutchfield or elsewhere, to accomplish the task without the need to hack things up. Many of us have aftermarket radios and the fobs and alarm work fine.
Ok thanks, i guess i might suggest RKE receiver, if fuse is good. I think i have one for an 04, I will glady send for a test unit. @Groceryman101 if fuse is good and you can't find one for a reasonable price. I will look for it and send to you for a test unit for shipping costs.
Not sure, but should be same part.
for 04 and 05 AND if I can find it.
I am not sure but i think it located under RDM, but might be under waterfall near BCM.
Okay everyone, I’m an idiot ( but a happy one ). After making sure the alarm worked and checking the remotes battery. I double checked the fuse again. All good. As I looked at the fuse box, I wondered could I be so lucky as the fuse being off by 1 spot. So I moved it down 1 spot and you can all guess what happened. Key fob now works. Thanks to everyone and of course special thanks to the Dictator. I can now open the door again for my lovely wife. 👍 😎
I probably did it while checking fuses at some point in time. The fob hasn’t worked in awhile and I just recently ordered new ones. When looking at the diagrams online ( I don’t have one on the truck ) there are a couple of gaps between the fuses, I obviously stuck it one off and never realized it until now after getting new fobs. But I’m good to go now. 😎
I just received a new fob from eBay, then found out my old one just needed a new battery... got fixed through my dealership. Also my #1 broke last year and I bought the last GM fib... had to have it re programmed... not inexpensive, but GRATEFUL ! Good luck!
tickledpink, Sue Campbell
Hi, Chiefmo here 04 Slingshot, I ordered new fobs and took them to Batteries and Bulbs to get them programmed. It was $40 to do both fobs. I had tried the procedure in the owners manual and it did not work.
