Does any one know what the key is for on the passenger's side of the vehicle by the emergency break.
Thanks
Thanks
Not a very good place to put valuables with top down. Also if you want keys any good lock smith can make one in about 5 minutes for $10. Just keep gum and pen and paper in mine. There is a guy on this site that makes what he calls "THE POPPER" which is a little spring with a screw and directions to install because of what you said about it not popping up. Once this spring is installed you push the button one hand and the cover pops up about 3 inches so you can open it very easy. I will try to find him.Don't think mine is locked, but it just decided on its own one day, it didn't want to unlatch anymore when I pushed in on the release button. The paperclip idea, above, prompted me to try a toothpick so as to absolutely avoid scratching the paint. Toothpick inserted under the forward lip of the lid, at a downward angle, gets you right in. Tried it successfully, repeatedly...
