1 - 4 of 4 Posts
Ex SoCal Nut
peek in there with the window down. take a can of wd40 or your choice with the soda straw attached and give it a shot and work it in. repeat on the other side door. corrosion due to dis similar metals. just needs some lube.
Discussion Starter #3
i didn't have much luck with the peeking, so I just squirted WD40 into the hinge areas (with the long tube nozzle) from the outside.
The next time I do this, the window will be UP!
Works great now.
Proud Original Owner
Years ago when I first got my SSR the driver's door handle wouldn't return back by itself. If I forgot to pull the handle closed when I got in, I couldn't get back out by the inside handle. Would have to roll down the window and reach the outside handle.
Dealer fixed it. No trouble since.
1 - 4 of 4 Posts
