Well no luck so far. I did get the bolts out that were holding it on. Only to find out that it will no come out of the space. I also moved some connector of sorts that was in front of it, still not enough room. It may come out if the fuse box is removed. I started on that an stopped. I had an idea that maybe it would come out the wheel well space. In the process I broke the only socket that fit it and the air wrench, had to go buy another, only to realize that there is metal behind the tank, not just the wheel well liner.
I put the tire back on, looked at it a while and quit.
I did get a better look at it. It may be leaking where the tube that goes to the wipers slides over a little pipe that goes into the tank. Sometime I might put some goop on it and put some more fluid in it and see if it leaks.
But not TODAY.
