Looking for a left front fender liner
I’ll check them out.Have you looked at the after market ones on Ebay? I got a set for my red truck but haven't got them installed yet. Seem to be of nice quality and reasonable priced and they will ship them no problem
Thanks, those looked a little shinier in the eBay photos. Are they? Also are they as pliable as the OE?@Hollister SSR I put in one of mine today. The passengers side. It had to be adjusted a little on one hole across the top and one on the lower rear was out and needed a little adjustment but other then that it fit ok. For the savings in price and depending on how picky you are would be the other things. I put it on a 100,000 mile truck and to me it was a lot nicer than what it had. I hope that helps you.
Thanks. More pliable with those things certainly can’t hurt.Yes they are shinier than the stock ones I took out and they are more pliable then the originals. They may even be a little thinner plastic. I will try to measure the other side if I put it in today. But keep in mind the originals have been in use on this truck for over 100,000 miles and 17 years. The more pliable was helpful in putting it in. I think I am going to go back and work on the lower edge when I have time to make it fit a little nicer. I was in a little of a rush when I was wrapping it up yesterday. Again I would not call them plug and play as they needed a little finesse to get it to fit and everything to line up. But for the price they were a good alternative for a part that no one is going to look at and it's only job is to keep the water out of the engine compartment
Haven't bought them, but saved them to my wishlist:Looking for a left front fender liner
