Guest
·How do you install license plates on these babies ? :leaving
Best place to start is this thread:2004 SPT TRCK said:How do you install license plates on these babies ? :leaving
Uh. Yeah. Me toowildcat66 said:Guess I should have asked front or back? [email protected]#%(#!!!!!
Taking my chances with not using my plate or plate bracket on the front. As for the rear, it's the same as my C5 was. If you look carefully on the inside edge of the black plate frame there are 2 small slots on each side. You need to use a flat blade screwdriver and insert it into the slots to lift up the small locking tabs at each slot. Then the frame just pulls off easily. It's a little tricky but if you pull slighlty while pressing in the locking tabs it will come off without breaking it. :thumbs2004 SPT TRCK said:How do you install license plates on these babies ? :leaving
Check out simple-engineering.com for many items for your SSRHas anyone tried tapping the license plate holes for a standard thread size? I've done that on other cars and it went well. What this does is give you an almost endless choice of hardware to mount the plate. I'm just starting to detail the small items of my recently purchased SSR. Some larger changes will be done over the winter months here in PA. For now, I just want to drive it!
