1 - 3 of 3 Posts
Just ordered a lighted Flameball gear shirt knob for my truck.
Need to find the easiest wire to tap for power when the HEADLIGHTS are on. Not interested in having it on in the daytime. I do have the gauge package it that helps.
Location of wire and color would be a great help.
Thanks in advance for the help.
Marc (bcbear 10)
Two choices
Marc,
Jumped into the Manual..... You have 2 options, both will work.
On the Aux Gauge connector:
pin 4 (Brown w/ white stripe wire) is dimmed lighting.
Pin 2 (Black wire) is ground.
On the Center console switch assembly connector:
pin 1 (Brown w/ white stripe) is dimmed lighting.
pin 10 (Black) is ground.
Attached is the schematic from the '05 manual for your reference. The JPG is kinda hard to look at on the screen, but it will print beautifully.
Best Regards,
P.S......Do you think GM would be interested in hiring me as an SSR Customer Support Engineer????:glol :glol :glol
Discussion Starter · #3 ·
Mike,
You are the best !!!! If GM had you, they would be in alot better shape then they are know.
Thanks for the speedy reply. I figured it would be you who would solve the problem. Now I can put her back together again.
Marc
PS: will be workiing on shipping the y pipe over the weekend.
1 - 3 of 3 Posts
