I suspect the question has to do with the screw drive units that newer vehicles have for tailgates and trunk lids so they can be opened AND CLOSED electically. I know RunrRodRun looked into that at one point but it was not fiscally practical.Kathy's '04 OEM"s can be closed with one hand. Sounds like someone has changed the one's on your SSR for Mike's stronger ones. Maybe someone has the OEM's they took off and would part with them. That would be a LOT CHEAPER!!! Others will have other ideas.
Careful there Nick...... you might want to find out where he bought his existing struts before you assume they are mine. The ones that Florida Stainless sells have at least 10 pounds more force than the ones I sell. I have come across them a couple times.Kathy's '04 OEM"s can be closed with one hand. Sounds like someone has changed the one's on your SSR for Mike's stronger ones. Maybe someone has the OEM's they took off and would part with them. That would be a LOT CHEAPER!!! Others will have other ideas.
Wondering if anyone has replaced the gas shocks on the rear cargo cover with linear actuators. Tired of muscling the cover closed and curious to know if this this been done and what was involved.
TIA
SSRGEEZER
Because of my relationship with Jeff (RunRodRun) and the modifications on his truck, I looked into this about 12 years ago when he wanted to have it. Yes, it is “do-able”.......I suspect the question has to do with the screw drive units that newer vehicles have for tailgates and trunk lids so they can be opened AND CLOSED electically. I know RunrRodRun looked into that at one point but it was not fiscally practical.
I will send you a set of LST struts to "test", if you would be willing......Mike (Simple Engineering) was correct. I DID buy a set of replacement struts from Gary (Florida Stainless) in October 2017. They work great when opening but are a real pain to close (so much so, my wife can't close the lid by herself and she's no weakling).
Also appreciate the input/advice from Mike about actuators. Sounds like the complexity may be a little beyond my ability (and possibly more than I want to spend) to have someone do it.
Appreciate the replies. That's what makes this website so great!!!
SSRGEEZER
You don't have to send any, he is in Florida and I have them in Stock, I keep your LST struts in stock for SSR Fanatics.I will send you a set of LST struts to "test", if you would be willing......
By the way, SSRGEEZER, your mailbox is full. I couldn't send you a PM....
Not trying to be a wise guy but I have a question. Are you closing the lid in the right order as described in the owners book. Mine closes very easily. You close the top lid first then the tail gate last. If you do it the other way around and close the tailgate first it is almost impossible to close the lid because the back is full of air you are compressing. It also doesn't seal properly as the gaskets were made to seal in the proper order. Hope that helps.Wondering if anyone has replaced the gas shocks on the rear cargo cover with linear actuators. Tired of muscling the cover closed and curious to know if this this been done and what was involved.
TIA
SSRGEEZER
Send me an email, Dave. [email protected]I don't know what the longevity is, but on the ones from Mike in Arizona, they lifted my lid for a couple of months. Now that just pop up enough to get my fingers under them to lift it up. Still have a lot of pull down on them though. I bought them last summer.
Depends on the ambient temperature too. In our summer heat in Texas the lid flies open but now in 40 deg temps it pops up and sometimes it slowly opens other times I need to give it a tug. I don't move too fast in the cold either!I don't know what the longevity is, but on the ones from Mike in Arizona, they lifted my lid for a couple of months. Now that just pop up enough to get my fingers under them to lift it up. Still have a lot of pull down on them though. I bought them last summer.
