the piece under the front of the truck that is shiny black plastic has worked its way loose are the plastic pins that hold it on gm only ..... must be a better way to hold this on has anyone else had this happen :skep
2006 Aqua Blur 22578
Any auto parts store should have what is commonly called xmas tree fasteners that should work.
The pins are a standard GM kinda thing. You should be able to pull one out and get a replacement part at your local discount parts store. I've seen some similar at Kragen/Checker. They're pretty cheap, even at the dealership.
The plastic pins are there in case you hit a curb with the air dam. The pins will break or be extracted before the lower radiator support gives.
Machell
If you are talking about the air dam deflector, better take it off before you lose it completely about 90bucks to replace. Lost mine earlier this year. Hubby still hasn't made me a new one. Oh well gonna order that front spoiler anyways!!!
Odd Coincidence
Wildcat,
I'm headed to the plastic fab shop this afternoon to look at my redesign for that part. It's vacuum molded with an actual slight scoop to it and a pair of ears (bent forward at a 40 degree angle) that curve upward and forward to match up with the curve of the front fascia. This part will look like it belongs there. :thumbs
If it meets my design requirements and fits the way I want it to, I'll be posting photos here tonight. :thumbs
Oh by the way...... For your reference, the actual cost of the stock Air Dam is $72.34 from your local Chevrolet Dealer. :banghead
air dam
Mike in AZ said:
Wildcat,
looking forward to seeing some pictures of it i know i would be interested in one. burt
