Well today Mike in AZ and I installed the aux. fan Mike designed and produced.
We tried a few different things apart from Mike's original install instructions that seemed to make things a bit easier that Mike may revise his original instructions to reflect these changes.
Thanks to Mike's expertise, guidance, and assistance, the install went flawlessly and quickly.
The fan looks and sounds great, very quiet. As it idled in his garage, the temp gauge held steady and the fan kicked in appropriately to maintain ideal operating temp of around 210, whereas before the install the idling temp was around 226-230.
The real test will be the travel back to Austin, TX and although at cruising speed, I do not think there will be much change, idling at anytime and after engine shutdown, the fan should do its job nicely.
Mike has hit a home run with his design, the look of OEM is unsurpassed, the ease of installation is unsurpassed, the function as a supplemental cooling device appears to be unsurpassed.
I, personally, highly recommend the purchase and install of this "can't do without" tool for your SSR.
Thanks again Mike for everything, you made the trip worth it.:seeya
OP
OP
