Installed Mikes replacement fan today , great quality product and fits perfectly as does everything from Mike. It took me slightly longer than the 4 min. 37 sec. that Mike took to install the one in Blur but still a job no one should be afraid to tackle.
Now for my question : I know you can force the fan to run by turning on the air conditioner on , but does it run continuously ? It is only about 74 here today and when I started her up (with the air on) as expected it took a few seconds to come on and then after 10 - 20 seconds it turned off came on again after another 20 seconds or so . I didn't hear the compressor cycling on and off from low/high pressure so don't believe that is a problem but I was not outside the truck so can't be 100% sure. So should it run continuously or is this normal ?
