If it met the spec wouldn't they say so on the bottle? Owners manual clearly states oil must meet the GM4718M spec. I wouldn't put anything in that didn't say it met that spec right on the container.:nonoWilliam said:Does anyone know if using Mobil 1 Extended Performance oil
is ok for the LS2 engine ? It doesn't have the GM4718M spec. on the
bottle like the regular Mobil 1 oil does ?
Thanks,
Bill
When this new oil came out, this question was posed to Mobil 1 by numerous people on the Corvette Forums. Mobil consistently answered that it isn't labeled to meet GM Standard 4718M because it doesn't meet the standard. As to why it doesn't meet the standard, that isn't clear. That's unfortunate, because for those who desire to stick with Mobil 1, this new oil appears to perform very well.William said:Does anyone know if using Mobil 1 Extended Performance oil
Thanks,
Bill
Personally, I would leave it in and replace it at the regular interval. You have a better oil in the car than required.JAustin said:So now, you Pit Crew members who know a heck of a lot more about all this stuff than I do: what do you recommend? Replace with regular Mobil 1 immediately? Replace at a shorter interval than normal? (And if so, when?) Leave it alone for now and replace as usual?
I appreciate your consideration of AMSOIL. Since I assume most (all?) of you guys aren't racing your SSRs, the AMSOIL SAE Synthetic 5w30 is what I recommend. This oil is roughly equivalent to the Mobil 1 Extended Performance oil as can be seen from the test result link of Nov 05 I posted above. I use the Series 2000 20w50 in my Z06 which sees exclusive track use, but I personally don't think it is necessary to spend the extra $$ on the Series 2000 0w30 for a daily driver. That said, if I had a new Vette, I'd probably be using the Series 2000 0w30 in it just because I want the best. :lolWilliam said::agree
JAustin,
I also have the Mobil 1 extended performance oil in my truck now,
but in 3-4 thousand miles I think I will switch over to Amsoil
because it does meet the GM4718M spec., whatever that is.
Now, Which Amsoil oil to use ?
The High Performance or the Series 2000 - severe service ?
Both have the GM4718M spec.
I've been running Mobil 1 since it first came out...way back when. I've got 4000 miles on my first changeSubdriver said:I appreciate your consideration of AMSOIL. Since I assume most (all?) of you guys aren't racing your SSRs, the AMSOIL SAE Synthetic 5w30 is what I recommend. This oil is roughly equivalent to the Mobil 1 Extended Performance oil as can be seen from the test result link of Nov 05 I posted above. I use the Series 2000 20w50 in my Z06 which sees exclusive track use, but I personally don't think it is necessary to spend the extra $$ on the Series 2000 0w30 for a daily driver. That said, if I had a new Vette, I'd probably be using the Series 2000 0w30 in it just because I want the best. :lol
Request a Free AMSOIL Catalog
AMSOIL Ordering Information
AMSOIL Preferred Customer Program
Thanks for your support... and no, you don't want to hear me talk about the filters... :lolSparky 2 said:I've been running Mobil 1 since it first came out...way back when. I've got 4000 miles on my first change
with the Extend Performance -
*but only because I didn't read the label*.
It's my fault, but I trusted Mobil to have it's bases covered with it's "Best" oil. Well...thanks to you guys - I just ordered the Series 2000 0w30.
Now, tell me how bad I screwed up by special ordering (3) DG Fram oil filters.:banghead :banghead :banghead
I thought I might have misread another label - but not this time - I've got a FRAM DG3675. Nonetheless, I bet I should be ****-canning my $13 filters, right?Subdriver said:Thanks for your support... and no, you don't want to hear me talk about the filters... :lol
The Fram PH and TG filters have very low flow according to this guy's study, but the XG appears to have fairly decent flow with average filtration. I don't think they make a DG though...
www.oilfilterstudy.com
I went back and looked harder at Fram's website and I assume DG is Double Guard which is a relatively new Fram filter. That filter has not been tested by the above site. I could not find a lot of data on the DG filter line. One thing I did find which concerns me a little is that this filter is impregnated with PTFE, a teflon additive that is released into your oil. Amsoil and most other top oil companies specifically do not recommend using any additives as they may not work well with the additive package already in the oil.Sparky 2 said:I thought I might have misread another label - but not this time - I've got a FRAM DG3675. Nonetheless, I bet I should be ****-canning my $13 filters, right?
I forgot to mention, AMSOIL still makes those same fantasic two cycle synthetic lubricants. :coolSparky 2 said:I guess I've been living under a rock with regard to AMSOIL. I used it in my snowmobiles in the 80's - but I've been missing the boat ever since.confused :cry
Can't help you on the Mobil 1. I have 15,800 miles on my SSR and 12,800 miles are using the AMSOIL. Will change oil at 25,000miles or one year, which is the next oil change. This is a recommended by AMSOIL and no warrenty problems. Very happy with the AMSIOL products. At 30,000 will change the trans. and diff. to AMSIOL products.William said:Does anyone know if using Mobil 1 Extended Performance oil
Thanks,
Bill
