Thanx so much Mike, I was fairly sure it came from something to do with the latch system, and I knew it wasn't a broken piece of anything. Again your a wealth of info. I'm a little surprised it became dislodged so easily but will certainly keep an eye on that in the future. Just thankfull it didn't hide itself somewhere.That's the hard nylon part that the handle pivot rubs on when you pull on the handle. You will need to take your tailgate apart again. you will find a small place in the handle to insert it.
The photo below is a spare handle that I have. It has a part identical to your piece with a yellow dot on it. It's inserted into the handle..... see?????
Regards,
