1 - 3 of 3 Posts
I am troubleshoot my passenger door wiring harness because I believe a wire is broken causing my window indexing not to work. I have checked continuity most of the wires and cannot get continuity on a green wire. Would like to see where it is supposed to go before splicing
04 SSR
Door diagrams for window indexing
Sorry to take a while to respond
I actually found 3 Lt green wires and 2 Dk green wires inside the passenger door
The two DK green wires - Rt mid range speaker and Side impact sensor -- no effect on window
One Lt green wire is Rt speaker
The other two of the light green wires may have an effect on window operation, so these are what I focused on
One of them is for the window motor position sensor
#1 is the wiring diagram - runs from window motor connector out the door into the cab and to connector C600 behind the right kick panel. Wire is highlighted
# 2 is the diagram of the window motor connector
# 3 is the diagram for connector C600 - note Lt green for window motor is B-9 the other is speaker.
#4 is layout of the door harness
Continued on next post
04 SSR
Door diagrams for window indexing part 2
Continued from previous post
The other Lt green wire that may effect window indexing is on door latch
#1 Door latch diagram - Lt green wire highlighted. runs from door latch C2 to C601 inside cab near C600
#2 Door Latch C2 diagram -- note there are three connectors on door latch two have 2 wire and one has three (even though picture shows all three having 2 wires). I am not sure which on it is, check wire colors
#3 Door latch diagram
#4 C601 -- Lt green wire is terminal G
There is also a lot of good information on window indexing operation on this and many other threads
https://www.ssrfanatic.com/forum/f5/passenger-window-indexing-engine-startup-222465/
I hope this helps ---
Let us know what you find out or if you need further assistance
You might also consider contacting Dinerman for an Ultimate Drive
https://www.ssrfanatic.com/forum/f22/ultimate-drive-149170/
And be sure to view dicktators fantastic and very helpful one drive
1 - 3 of 3 Posts
